Number 1 plug miss fire?????????
In that case, I would say see if flashing the PCM helps. If the motor is running fine, then it isn't missing. Just the computer is telling you it is. Also, if it is running fine, the injectors are working like they should.
The coils can be tested to see if they are working properly. Did the shop do that?
