Keyless Entry
A dealer should be able to look up the VIN# and get the code assuming it wasn't changed. If that is the case, they should be able to reset it for you. I am not very familiar with it for DIY...
Good Luck!
Uodate
I did a litle more research online, nd found out teh module is under the dash on the driver side. I managed to sit on teh nerf bar and look under with out too much trouble. It is real easy to find. It is a white box labeled keyless entry/ security module, with the number printed right on the front. I now have keyless entry that works.
Glad to hear it wasn't too big of a deal. Saved you 20 bucks, that I would have spent. LMAO!
Good thing the previous owner didn't change the code on ya.
Is there any way that you might be able to find those links you researched, and, post them here? This way, the rest of the people that may have any questions about this same subject can go right there, and, get the same info. Can never have too much for our FORDS on the #1 Ford forum there is.
Here is a link that has instructions to reprogram. Not sure if this is teh smae one I had, I will have to look at what I printed when I get home.
http://www.fordf150.net/howto/keypad1.php
Here is the one, I actually used.
http://where-is-the-ford-keypad-inst....blogspot.com/
Now its MY Birthday!
