EXPY Plow Mount???
I think what you are seeing is his shadow on the lower mount because I saw this and thought the same this at first. I would check it for straight as well by measuring the bolt holes on the top of the carriage to make sure it is square and straight. Just an FYI new they are about 1600 new.
I would not take a torch to it you will take away all the strength from the steel. If it is bent just leave it where you found it.
Oh, nothing is seriously bent at all, just a little bit. I'ma see how much they want for it. I Want to put together a plow setup for the truck. Just doing driveways and such, not abusing my truck too much
Have you ever pushed snow with a truck before? Because if you have'nt you can do some serious damage to your truck as well as a person's yard and property if you have never done it before. I have pushed snow for many years and its not as fun as you think it is and it costs alot of money to fix a plow if you break something and it is a PITA because it will alway breaks when you need it most. Just do the math on what ball joints worth and replacing them every year if you carry the plow on your truck for long period of time.
