reverse sensor ?
reverse sensor ?
My 05 expy's reverse sensors (RSS) are apparently failing to work. Anyone have any ideas on how to trouble shoot the system. I am going to check for blown fuse today, but I have a feeling the fuse is not the issue, due to the fact that it was working recently. It is almost like the sensor tappered off from the 6 feet down to 5 feet ect... over the past month and does not work at all. Thanks for the help!
Does the off light on the dash switch stay lit? If so there is a fault with the system,A Factory scan tool is needed to retrieve codes from the RSS System most likely 1 or more of the sensors is bad,My F150 had 1 bad sensor dealer wholesale on the sensor was like $80! I got one off eBay for $25
It should have a switch on the dash so the system can be turned off when towing a trailer,If there is a fault in the RSS System the OFF in the switch will glow it will also glow when the switch has been turned off,If there is a fault in the system you will not be able to turn the RSS on by pushing the switch.
