98 expedition center console
Do you have the console where the A/C runs through it and you have a sunroof, or do you have no sunroof and the A/C ducts are in the ceiling? If you have the ceiling type of rear A/C you don't have to get rid of it, but if you have a sunroof and the A/C is in the console, all you have to do is remove the console, the duct will come out of the lower dash, and all you'd have to do is block off the hole somehow. I may even be able to swap you the part you'd need, but it depends on what set up you have.
