Air Ride shot...I think.
Ok...I've searched the boards, and found some info. A bit of it was well above my capabilities as far as testing relays/circuits and such.
My compressor on my 2000 Expy will not come on. My a$$ is sagging. It worked fine whan I parked it 4 days ago. The check Susp light is on.
The big question is...when I take it to the dealer...are there certain questions I can ask to help make sur I dont end up buying a crapload of parts so they can "diagnose" the problem via my wallet. I have no problem paying for good work but dont want to be paying for "parts as we go" diagnostics.
ANY help will be a bonus. thanks for reading.
Tim
Tim
Before taking it to the Stealership, I would call Eddie at American Air Suspension. He is an air ride guru. He was a FLM Tech for over twenty years before he went on his own. I also own a 1998 Lincoln Mark VIII that was plagued with air ride issues and he can walk you through the issues and get you any parts you may need, which will be cheaper and better than anything Ford will sell you.
You can check out his site at www.americanairsuspension.com or you can call him at 1-423-487-4321.
So after I thumbed through the shop manual, not much help for me as I don't have a scan tool (I do have a ScanGuage, but it read no codes), my next stop was here! Shoulda stopped here first, but I was already dirty.
Thanks for the link, it's way more than just a store! Tons of helpful links! Showed me where to look for an air leak in my '00, and it was the #1 spot, the union at the master cylinder, not sure why a 4x2 has a conection there anyway, but going to order a couple of connectors and extra hose just in case! Still less than $20!
Thanks!!!
