Cluster Questions...
I have a 97/98 F150 that I am swapping random pieces out of in turn for Navigator parts and was curious what kind of adjustments I would need to go through to adapt a cluster out of a 98 Navigator with the analog odometer, mileage is not an issue. My current cluster has only the Speedo, Oil, Gas, Coolant,and Charge gauges as the new one has a tack in it also will I need to tamper or is my truck wiring able to adapt?(similar to how the fog lights will work given you change the switch to one with the pull out fog function)
Thanks a bunch!
Thanks a bunch!
There is no programming, it is 100% analog. There are some subtle differences though, that I learned of while hunting for white face layouts for it. Personally, I wouldn't waste the time effort or money in doing such, as there is absolutely nothing special about our clusters, less they say Navigator on them
This is the cluster, and yes you are right there is nothing spectacular about it other than I like the layout of it, it's in better shape than the one in my truck and the tac is integrated into this one. I only paid like twenty bucks for it so no real loss if it doesn't work.
Plus i do plan on accenting the fascia with some lincoln navigator type emblems once I have it.
