broken key and theft system ugh!!!!
on
If the microchip inside the black head is damaged or lost....
Choice 1) Call a mobile locksmith who has the right equipment (ASK!)
Choice 2) Tow it to a Ford dealer.
There are no other choices if the above applies.
If the microchip is still available and is good and your key is still able to operate the cylinder, secure the microchip within range of the pickup coil (surrounds the cylinder) and get a generic key cut to replace the damaged one.
If you have an Edge/Ghryphon, put it back to stock before you go in as the dealer will most likely reflash.
on
Pull the column shrouds. Then, carefully remove the ring from around the cylinder. Secure the PATS key inside the ring, then try to start the engine with one of the plain keys. If it works, secure the "rig" and button it up.
I did this on my old Contour as a way of not messing with the PATS bypass for a remote start a few years back.
Project Sho89 is the most correct. The PATS key must be within the key coil for the system to detect the key. Sometimes this is also done when installing some remote start systems when the system bypass unit has become unavailable. Some remote start systems can come with a very good start inhibit system of their own.
