removing front console
Pull up the rubber mat in front of the cup holders and lift the arm rest. There are torx scres there, remove screws and lift off. Then there are 2 8mm or 5/16 bolts at the bottom that go into the floor board. The move the seats all the way forward and remove the 2 side caps and there is a bolt on each side, same size as the other 2. Then slide the entire console toward the rear of the truck. The disconnect the wiring if you need to fully remove it. Well, that should work.
99 Expedition 2wd 5.4L, Silver w/Dark Grey Int, Billet Grill, Door sills, pedals, brake cover, ant, wiper covers, fender badges, rear view mirror. Shaved roof rack & tail gate, fog light bumper color matched. Clear front corners, WMS intake, directional mirrors. DJM control arms, Toxic shocks, Front and Rear Airbag suspension with 4 wheel independent control, 20in CEC's w 295-40-zr20, Alpine CVA 1005, 12 disc changer, TV, VCR, Alpine speakers, subs, amps. Clifford Avantguard G4, Front and Rear Smartwindows, and Pagemate 4, Corbeau Targa RS seats, fully Dynamatted from front to rear, Nav tail lights, HID headlights.
