What size radiators in the '01 Expy
You may have seen the issue raging on the truck boards, all of the 2001 F150 owners (as far as we can tell) who purchased the 5.4L engine with tow package got a radiator that is 1.02" wide. Specs for my SuperCrew indicate it should be 2.2", other trucks may be 1.42", but it is clear that Super Cooling is an upgraded radiator.
My question is this, what size radiator do you 2001 Expedition 5.4L owners have whom purchased the tow package (and along with that got the Super Coolong).
You may see where I am going with this, if you have a larger radiator (as expected and paid for) I believe it becomes more difficult for Ford to tell me that the specs changed and my SuperCrew has the correct (smaller) radiator.
Thanks!
Craig Brossman
2001 SCrew 5.4L 4WD Lariat
Az Beige/Wedgewood Blue
Cpts. chairs, Moon roof, Tow package, CD changer
3.55 lim. slip, Rear slider, Skid plates
Mods:Ford Bedliner, Ford BugGaurd, Westin Step Bar, WeatherBoot Floor Mats
Thanks!
Craig Brossman
I've got the tow package too. As soon as I get back to Texas (I'm in Mass. for the week) I'll check mine. I've wondered since reading about the issue over there.
2000 EDDIE BAUER EXPEDITION 4x2
-->Come share my Addiction<--
- Estate Green
- 5.4 ltr
- 3:55 LS rear
- Superchip!
- Airaid FIPK
- Gibson S/S Swept Side Cat Back Exhaust
- Hellwig Rear Anti-Sway Bar
- Xenon Super White Headlights
- Tow Package
- Rear Load Leveling
- Moonroof
- Century Child Seat!
- Front Polyurethane Anti-Sway Bar Bushings ordered
Just took a look at my 01 Expedition 5.4L EB 4x4 with tow package. It has the 1.42 in. radiator. I checked on the Ford website and it says the 01 Exp with the 5.4L and tow package comes with the 2.2 in. two-pass radiator. I guess they made a change to the 1.42 in. single-pass for the towing package.
Mark
01 Expedition EB 4x4 5.4L
Previous Fords
99 Expedition XLT 4x4 4.6L
97 F150 SCab XLT 4x2 4.6L
94 Ranger SCab XLT 4x2 4.0L
Mark
Previous Fords
I checked my 99 4x4 EB last night. Best I can tell it's bigger than 1". I measured it the best I could and it's bigger than 2" also, and I'm pretty sure that doesn't include the A/C which is in front. There is a lot of "stuff" around there. I know there is a trans cooler, and I think there is even a power steering cooler. I will really have to look at this closer. Definitely bigger than 1.02 inches, although '99s aren't part of the issue. Bad news is I found a leak from somewhere.
Well guys I think you are on to something
I took the plastic cover off of the top of the radiator and guess what mine has the single pass 1.2 inch they have it hid pretty
well and I would never have known had I not
been reading these message boards.
something stinks about this deal.
2001 EB tow package
2001 EB tow package
One thing to keep in mind, there is a post, (can't remember where) where someone found documentation where the design of the radiator was changed. If they redesigned the radiator to perform equally or better and keep the size/weight down, that's a good thing.
- Estate Green
- 5.4 ltr
- 3:55 LS rear
- Superchip!
- Airaid FIPK
- Clear Corners
- Tow Package
- Moonroof
From 2001 Ford Specifications:
www.fordtraining.com
**2001 F150 Radiators**
1.02" 13.97 Fins/Inch
1.02" 16.50 Fins/Inch
1.42" 15.24 Fins/Inch
**2001 Expedition Radiators**
2.20" 10.16 Fins/Inch
As I noted in an earlier posting I have the 5.4L and Tow Package and I got the 1.42" radiator. It seems like there is a 1.02" inch radiator that Ford may claim is an upgrade from the standard 1.02". They may or may not be right but I'm glad I got the larger 1.42" one.
