Expedition / Navigator
Tire Pressure
Old 05-21-2001 | 09:18 AM
ranwin's Avatar
Question Tire Pressure
I've noticed the door panel on my 01 Expedition states the PSI for my Goodyear RTS 255/70R16 tires is 30 front and 35 rear. Is anyone running them at that pressure?
My dealer returned the Expy after servicing showing 35 psi in all tires, although a later pressure check indicated they did not check the tire pressure as the fronts still had the 30 psi.
Old 05-21-2001 | 05:42 PM
hdlouie's Avatar
Talking
Yes I run mine at that psi, but I have LT tires on my X. I Wouldn't run any lower than 30 on the front or rear. I have no complaints with that psi.
99 Expedition XLT,5.4L,4X4,3.73LS,285-75-16 KO'S9(old 17"AT/S),Airaid Intake,Superchip,Edlebrock shocks,Dynomax Super Turbo 3",Helwig Sway Arm,Polk speakers
http://home.earthlink.net/~louladot/
Old 05-21-2001 | 05:45 PM
Tampa-Harley's Avatar
Post
yes you should run the manufactures recommended tire pressure
not the pressure on the tire but the pressure on the vehicle tire pressure info car all cars trucks have them!
Old 05-22-2001 | 10:45 AM
EnzoWho's Avatar
Post
I would run the pressure set by Ford if you are running the tires that came with the truck. Once you change tires, go by the tire manufacturer's data. Ford has no idea what Michelin, Dunlop or Bridgestone tires need to be inflated to.
Our vehicles run on light-truck tires. The manufacturer of these tires know what type of vehicles these tires will be purchased for, and have a tire pressure range that will meet most of our needs.
Call some tire stores and ask for yourself if you don't believe me.
Quick Reply: Tire Pressure
