Rear door interior removal
I have a split in the plastic covering the rear door. Apparantly something in the cargo area shifted against the rear door causing a 4 inch split in the plastic. I am going to attempt a repair with one of those plastic/vinly repair kits, but I need to take the door interior off first. I can't see any screws. Does the cover simply pop off?
VettMeister;
Try this thread for the SuperCrew. Suspect the doors are similar. Pictures of the rear door removal are towards the bottom. Best of luck....
https://www.f150online.com/f150board...ML/000092.html
2001 F-150 Super Crew Lariat 4x45.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Roll-up bed cover; Six disc CD changer in '98/'99 Expedition center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX subwoofer in custom built, center console, sealed enclosure; Zapco AG150 amplifier; DRL daytime running lights with Fog Lights (Mod)available at all times;
Bel 980 Radar detector; Moon roof; Bed extender; Class 3 trailer hitch; Factory splash guards (front & rear).
VettMeister,
There are just clips holding it on. I took mine off once, it just takes time. You have to pry it off. I started at the outside and the used a long screw driver to reach further into the panel to pry the inside clips. Just be very patient and it comes off easy. And also be gently when prying I put a crack in mine when I got to forceful with it.
Brian
Brian
