Adding Auto Lift Gate
I didn't think to search for that, we've had the head liner out a few times for AV install, and i thought I remember seeing a mounting area and some extra wire harness's back there. Not sure, may give up on this quest.
The Auto Lift Gate was available on the 07 and above.
I have it on my 08 EL Limited.
mechanically, the install would be a simple bolt up. remove that left rear interior panel and replace it with the auto-lift panel.
then bolt up the auto-lift unit and attach the lift arm to the rear hatch.
Ford likes to pre-wire stuff. so I would personally look behind that left rear interior panel first. if there is a wiring harness there just hanging out, odds are that it belongs to the lift gate.
then check the dash above the radio by the hazard button. if you have a harness hanging out there as well, you are probably good to go on the electrical side.
