shifter problem
shifter problem
hello all, i have a 97 expy with a shifter problem. i came home from a trip and my daughter says the expy won't go into park and the key is still in it. i started by checking the cable and shifter at the trans, all is good down under, so then i started on the column. after removing dash pieces i found a broken hold down clamp(pn 7e400) that allowed the shifter assembly to move around instead of staying straight. still no park. when i went to my local ford dealer for the clamp, they said 2 other parts could be broken,pn 3e723 and 3e715, 2 plastic parts. problem is i can't see them to check if they're ok. anybody know what i'm looking for or had a similar problem?
