Does this panel come off?
The panel is part of the passenger side air bag module. From the looks of it, you'd have to remove the whole module (you can't just remove the panel.)
Removing it seems easy, though you have to deactivate the SRS (airbag) system first. You don't want the thing going off in your face...
Have you checked it isn't something in the glove box?
This is for the 2000, right?
1. Remove the top steering wheel cover. Moving the shifter to 1 might make it easier.
2. Release and set aside the electrical connector that down there.
3. Take off the fuse cover.
4. Take off the screws (should be 2) on the hood release hatch, and release it from the lower shroud.
5. Take off the screws (should be 2) on the parking brake release, and release from the lower shroud.
6. Remove the 6 bolts, and take off the lower shroud.
To install, reverse the order.
