Running Lean?
My 2003 Expedition 5.4 had the Check Engine Light come on, had the 0174 lean code read, and it was my vacum lines - apparenlty its really common for the rubber elbow on the PCV valve to split (near passenger side) mine hadn't split, but was perished - I didn't have the elbow to replace it, so I just used high temp water hose and a 90 degrees joiner - worked well and after my battery was diconnected I haven't had any more light or codes
Google Expedition PCV elbow, and there will be pictures of the location and part numbers etc..
Mine was the elbow on the very back of the upper intake underneath it a little..pita to get to...bought the whole assy from back of intake to Pcv and to front of intake for 40 bucks from Planet Ford...huge spyder assy allmost every vac line on passenger side. 5.4L btw if there is any difference.
