Expedition / Navigator
2005 Expedition with a miss
Old 01-31-2013 | 05:26 PM
rktolds's Avatar
I am chasing the infamous mis the 5.4's have. I have a misfire code for number 5. I have done the following:
New coil for number 5
New set of plugs and boots
New injector (per repair shop using bore scope and saw irregular spray pattern)
Switched coil to different cyl when the code came back thinking I bought a bad coil. I'm still having a rough idle and the CEL came back on for cyl number 5.
What else should I look at? Truck has 137,000 and runs strong down the road.
Thanks,
Matt
Old 03-29-2013 | 11:51 PM
99Lightning's Avatar
We're having the same issue with our 2005. We have 109k miles on it. Changed plugs within the last 500 miles.
Old 12-17-2013 | 02:17 PM
LightningCrew's Avatar
Did either of you resolve this issue? Buddy of mine has an '05 with a similar problem and we are trying to fix it.
Old 12-23-2013 | 12:31 PM
rktolds's Avatar
I finally went to my local shop after I was chasing my tail. What I found out was the roller rocker had failed and worn a groove into the cam. So I had a stuck exhaust valve. It ran awful of course. To fix it I needed a new cam,one rocker replaced. I didn't find this problem doing research on the net so I doubt it happens a lot. The truck only had 145000 miles. The plug removal and coil replacement is pretty straight forward if you follow the instructions. Good luck with it.
