fuel economy
Re: fuel economy
Originally posted by rjp
my 98 expedition seems to be awfully thirsty!! The estimated fuel economy ratings were 13 city 18 hwy. It is not even close to this estimate!!!!!!!! more like 9 city and 15 hwy; what is everyone else getting? It has the 5.4L engine
2000 5.4L 4x4
10 City, 12 City/Highway, 14.5 Highway
I can understand how mileage might be variable in the city, but pure highway driving should not produce the the huge disparities that some mention unless there are hills/mountains, winds and significant temperature differences, etc. You also must consider rearend gear ratio.
Whenever I mention highway figures I try to specifically include only those on relatively open, flat roads without severe wind conditions and without heavy loads...anything else would be misleading.
My miliage bites as well.
This is a spreadsheet that I keep on mine. Judge for yourself. I consider myself to be a conservative driver.
Date Miles Gallons MPG
8-Nov-2000 274 19.205 14.26711794
11-Nov-2000 259 18.394 14.08067848
16-Nov-2000 321 23.408 13.71326042
26-Nov-2000 232 21.331 10.87618958
10-Dec-2000 312 24.245 12.86863271
19-Dec-2000 256 20.883 12.25877508
30-Dec-2000 227 19.279 11.77446963
12-Jan-2001 275 22.921 11.99773134
22-Jan-2001 320 24.784 12.91155584
29-Jan-2001 418 24.017 17.40433859
7-Feb-2001 318 24.244 13.11664742
12-Feb-2001 354 23.788 14.88145283
19-Feb-2001 342 25.461 13.43230824
27-Feb-2001 319 23.915 13.33890863
7-Apr-2001 313 24.501 12.77498878
15-Apr-2001 282 23.617 11.9405513
17-Apr-2001 342 24.753 13.81650709
29-Apr-2001 293 26.362 11.11448297
5-Mar-2001 284 21.751 13.05687095
11-Mar-2001 322 23.589 13.65043029
15-Mar-2001 179 12.576 14.23346056
27-Mar-2001 305 24.13 12.63986738
9-May-2001 276 18.557 14.87309371
18-May-2001 280 24.811 11.285317
25-May-2001 250 24.741 10.10468453
31-May-2001 266 23.041 11.54463782
8-Jun-2001 290 25.493 11.37567175
16-Jun-2001 226 20.929 10.79841368
10-Jul-2001 266 23.633 11.25544789
20-Jul-2001 296 26.041 11.36669099
12.758 Avg MPG
97 Teal Green XLT
5.4 ltr
JBA Stainless Headers
3.73 LS rear
4 Wheel Drive
Steel Horse Billit Grill
Xenon Super White Head and Driving Lights
Tow Package
Rear Load Leveling
Altezza Tail Lights
Euro clear Corners
Euro Clear Headlights
2000 Wheels
Ford fog lamps
Ford Bug Deflector
http://www.outlawtrucker.com/expfront72.jpg
http://www.outlawtrucker.com/expback72.jpg
12.758 Avg MPG
97 Teal Green XLT
5.4 ltr
3.73 LS rear
4 Wheel Drive
Tow Package
Rear Load Leveling
Altezza Tail Lights
Euro clear Corners
2000 Wheels
Ford fog lamps
Ford Bug Deflector
Highway driving
Originally posted by jimmsimm
2000 5.4L 4x4
2000 5.4L 4x4
Mine varies, but...
I drive to the other side of the state every other weekend for "Cougar" football (had to throw thatin, I am a Washington state fan)! It's 325 miles and I get there on a tank. But I must confess, half of it is two lane (PASSING REQUIRED).
When I took it to Canada on a road trip of mostly flat, 70-75 MPH, it got 16.5 MPG.
On another note!!
Anyone see the Dutch Auction for JBA stainless headers for Expy's? $425
RedExpy- Did your mileage really improve THAT MUCH with headers, catback, and intake?
On another note!!
How to go longer between fill ups
This is not going to change your average miles, but will increase how often you have to fill up.
I noticed that with my truck I have a 27.? gal tank (however I have gotten 28.4 when almost bone dry). However, when I fill the truck up, at about 19-20 gal, the pump shuts off. When I check the gauge, it reads full. But as I mentioned before, my tank is at least a 27.? tank.
If you fill and click, fill and click, fill and click another 7 gals or so, it helps. That is at least another 70 miles!
I am not sure what causes this issue, but assume it is due to improper venting of the air the gas replaces. The gas goes in faster than the the air can get out. I have seen people say that if ou turn the pump upside down that helps, but the neck on my 2001 will not allow that as an option.
Just a tip that I have used and it does fit. HOWEVER MAKE SURE YO FIND OUT HOW BIG YOUR TANK IS. NOTHING WILL RUIN A PAINT JOB FASTER THAN GAS ON IT.
[begin rambling]
I haven't chimed in on MPG in a while.
Around town bone stock I would get 12-13. That includes som hwy driving but in rush hour so it could be stopped. On the hwy I would get 15-16 running in the 70-80 MPH range with AC on.
After the chip, filter and exhaust:
I get about 14-15 with the same around town driving and 17-19 with the same hwy driving.
I'm now towing a 7200# boat and was scared to see what kind of milage I would get. I've heard stories from Ford truck owners of 9-10 MPG with a sizable load. Always getting out-done by Chevy's. Well so far, hwy driving at about 55 MPH I get 14+ MPG, 65 MPH drops to about 12-13 MPG average, hills and all. Around town, stop and go with that weight it's closer to 10 MPG.
A week or more ago on the way to work I reset the on-board overhead as I was getting on the frwy that was flowing pretty well. It's been cool here in north Texas so the AC was off. I got a steady 20-22 MPG strickly on the hwy with no AC for 10+ miles. When I pulled off the hwy and started in normal "city" driving, it started dropping by not much. Right now after about 1 1/2 tanks since I reset the on-board, with a lot of local stop and go towing of the boat and stop and go commuter driving, I'm sitting on a little over 13 MPG and every time I get in without the boat it's going up. My commute to work is about 22 miles and it will increase by about 2/10's each way so MPG is good, without the boat.
Now if someone would come out with a super low drag or electric compressor I bet milage would jump 3-4 MPG. I'm not sold on underdrive pulley's yet and I haven't gotten motivated to do the electric fan yet since I think to do it right, there are a few other things I'd like to do. Some gauges, manual fan for tranny/oil cooler, manual override and all this with OEM looking install in the interior! There just not a really clean place to install gauges and keep the EB Expy look and feel.
[end rambling]
[end rambling]
You know family ride mine is just like yours and I get 14.5 around town and about 19 on the highway if you keep it under 74 about. That is with the modz listed below. It got a litte less without the modz but I only drove it about 1000 miles before I did all that stuff. Good to see that stuff is consistant....
2001 Eddie Bauer 2wd
On the interstate last summer with the air on we managed 17+ mpg @ 75-80 mph. Have not been on any trips for a while and it is registering 12mpg. I reset the meter after the vacation and all driving since (3000 miles) has been short trips less than 10 miles around town.
I had a good tail wind but I left Flower Mound TX just north of Dallas and got gas again in Demopolis Alabama. I got 21 miles to the gallon. I was just driving around 65 because it only had about 400 miles on it at that time. It was like 530 miles on that tank full. Crazy. Last trip to St. Louis was 17.5 but that was before modz. I set the computer before we left, drove to STL and drove around STL for 3 days, and drive back to Dallas and got 17.5.
Later
Later
