Towing Package
Thanks PhillipSVT for your help. I do have a 4x4. If you can get p ictures that would be cool. The four corner suspension sounds good. I was told that my 2001 was loaded. At the time I wasn't really technical on the details of what was all the options but the standard equipment that came with the EB.
It is more than likely you have the LLS. Does the truck make "clicking sounds especially when you turn it off"? Also get a flashlight and look under the glovebox on the right side and if there is a rocker switch then you definitely have it. By the way if there is a switch make sure it is turned on. Good luck.
