Exhaust header to head Leak 5.4l '97
Anyone else get a leak on passenger ex manifold?
I am concerend about head errosion on the AL. Got stock gasket and manifold ready and am waiting on studs before I go at it. Looks like the stock (all metal, 3 piece wafer may not conform it the AL head is burnt at all. Going to try it next week, got high temp locktite (2000 deg) "glue" or gray Si on hand. Any thoughts?? I get a fait amount of road sat rust on old m folds
Mark in Ohio
Mark in Ohio
I already have a set of takeoff manifolds from a '00 Lightning.
They look different than my'97 ones, but look like they will fit.
I expect they are like expy 99+ , look like they will flow better. For right now (before winter sets in), I'll gunna try to bolt up one (passenger side), wonder if I'lll pick up a horse or 2 per side. Anhow, one side will hopefully fix the slight leak. Heads sound cooool , but this IS a family ride (winter beater/Tow vehicle) and on a family budget. Just trying to get ready for snowmobile season WHEN WINTER DOES arrive up here!!!
I read somewhere on the net of a guy who is having dealer REPLACE head for leak. Said it erroded the AL head a bit. Dealer was to reduce cost of repair,out of warrenty (98). I think he was up north too. I think rust (road salt) plays a part. My nuts and maniflod (passenger)_ is wooly with rust.
Mark in the rust belt
Hmmm... wooly nuts and exhaust... my how this discussion *could* deteriorate!
I think you'll want to get that changed ASAP. The exhaust gasses will continue to eat away the head until you have to replace both manifold and head.
Headers, in and of themselves, are not obnoxious/loud. If the L manifolds don't fit, buy a set of aftermarket headers. Leave the muffler alone and you won't notice much, if any, change in sound.
UPDATE Just finished putting it back togrther. Broken Mainifold stud on rear passenger side Exh Manifold . Broke off below flush, but easy out (square kind) got it out. Some studs came out with nuts (hot,cold soak.... wait a day). Looks like road salt ate some of the head but not heat. sealing surface still good. Salt made the stud rust where it goes into the manifold. Used a little copper silicone on the head side of the back port. I also took a few minutes to rivet some rubber sheets onto innner fender to expose less to the "shower" of salt/slush that I drive thru. I would recommend this added protect for all rust belt guys as I dont want to do this every 5yrs. (if i had let the slight "tick" leak go,The head may have been junk ($$$$$$$). ( also I put a quick flap to protect horns/fog light) thanks for the help Mark in Ohio
