Door Panel Removal
Two more screws, one under the courtesy light at the bottom. Take the lens off and you'll see it. Two is under the power switch control panel. Carefully pry up each end of the power switch panel, disconnect switches and remove. AND one bolt which is under the door handle. Carefully pry out door release trim, starting at the edge closest to the speaker grille. Rotate trim to expose a 5/16 bolt in door release handle, remove handle.
Slide the door panel upward to release, disconnect the courtesy light and remove panel.
Got this off the Cruthfield instructions, hope it helps.
