keep your eyes out for 2003 's !
if any one see's a 2003 expedition or navigator with after market
wheels please e-mail me or post them , im wanting to get wheels
bad but i want to see one first. so keep your eyes open for me
thanks alot
chris
superiorlaser@worldnet.att.net
thanks alot
chris
Originally posted by sjLightning
Im just curious how these trucks w/aftermarket wheels respond w/the stability control..
My advice would be to leave the 22s 23s & 24s to the show trucks and boulevard cruisers. A real daily driver, even one that doesn't venture off-road, shouldn't be handicapped and needs to be able to actually survive a trip down a bumpy road or a rail road crossing at speed.
BTW, keeping your tire pressure at the correct levels is very important, even more so when you are dealing with low profile tires that hold less volume of air.
Rollin' on Dubs-
Well, I'm rolling on dubs, and have been since January in my truck and since April in my Expy.
My trucks have been down the mean streets of Dallas, and the pot-hole strewn interstate through Louisiana, at speeds up to- well, let's just say a radar detector is a good thing.
Anyhoo, I agree with some of what Petrol said. Once you move up to 22's, you better pre-plan your route to minize bump exposure- Every Expy/Navi/Escali rolling on dubble-dubs, or twanky-fours have been 305/35/22, or 305/45/ 22 305/35/24's etc..
That leaves very little meat to protect that rim on a bump. Plus, it gives the truck a "Stage Coach" look if you will. I don't mind the big wheels, but I like big tires too. I also heard that strapping on some run-flats may help protect the wheel once you go into the 22-24 range.
I have 275/55/20's on both my trucks- No problems with the wheels, yet... Next step, 305/50/20's... Although the aspect ratio will be lower in number, because it's based on a width of 305 instead of 275, my sidewall thickness will actually increase from 151.25mm to 152.5mm.
Also- I have Centerline Avengers on my Supercrew- it is a forged aluminum wheel, that is actually 2 lbs lighter than the stock Ford 16" wheel, and is a stronger wheel. Therefore, it reduced the unsprung weight on the truck. My Expy has AR / Vanguards, which turned out to be 14 oz. heavier than the stock 17's.
If I noticed anything, it was a smoother ride than factory- even though I have taller wheels with thinner sidewalls.....
Go figure....
Go figure....
Ok, i saw an 03 X-EB (red) at the gas station tonight.
it was rolling on some aftermarket KMC 20s.
the guy driving it said that he took it to discount and asked what they had that fit it, and they brought out a six lug wheel and bolted it up and it fit, he did not know if it was a chevy 6lug wheel or not, but he said it fit and it looks nice to me so i had them mounted up.
