Help with AWD slip on 99 Expodition
I'm new to this site and not sure where this question should be posted. I have a 99 Expedition, E B, with AWD, 5.4 L and 3.73 rear.
My problem is I have chatter or skip in the rear when accelerating but more pronounced when towing. It feals like Im on snow or ice and the power is being shifted from one whell to the other. The 4x4 light has come on the dash and blinks at a consistent rate. I just had a 60K check and had all fluids changed and an additive to the rear end to help with the internal clutch? The diagnosis yesterday was the reason this is happening is my tires have a ½ inch difference in circumference from front to rear and the computer is picking it up as a change and terrain and initiating the AWD / Control Track 4x4 system!! Has anyone experience this or heard of it. The tires have only 15k on them (replaced under recall). If anyone has any advice I’m all ears.
A 1/2" difference in size between the tires would probably cause this because the transfer case sends power to each axle based on the rotation of the two drive shafts. If there is a difference, it sends power to the front. When the difference is gone it starts to unlock again.
Does this only happen in the AWD position or in 4H as well? If this is the problem, it would go away when you engage 4H.
Ian
Ian
Thanks for your thoughts.
I haven't tried running it in 4wd on pavment but I'll check it out on the boat ramp this weekend.
The 1/2 " difference is in the circumfrance of the tires as a result of not rotating sooner than the 15K (which was just done). A 1/2 inch variance in circumpronce is a small amount on the radious or tread height. I'm guessing but it cant be more than a 1/16" difference in tread height. I can't believe the computer or design of this system would be so sensitive to pick up on this. The service department recomending rotation every 6k. I din't have this problem when i was running the origional Firstones which were replaced at 45k miles under the recall. The service department thought my only option at this point is to replace all four tires with new and start over with regular rotation.
I say its to expensive and I'll run it the way it is.
Will the computer recognize if the tire wear back to a close height of each other.
There was a defective sensor in the transfer case in 99 Expy's. There is a special service number for the Fix, but I no longer have the number (sorry). I do however have the name and phone number of the engineer that made the fix at Ford.
What happens is, the sensor senses slippage when there really isn't any slippage and transfers the load to the front wheels. Once the load is transferred the sensor decides that there really isn't any slippage and transfers the load back to the rear wheels. This all happens so fast, it feels more like a bad spark plug miss under load.
One test you can run, is to lock into four wheel drive. If you do this, the transfer case is locked and can't transfer the load back and forth. And you won't feel any slippage. But once you go back to AWD then it will happen under light to medium load. You won't feel it under full load, because the transfer case will automatically lock.
Hope this info is helpful!
**** Murphy
**** Murphy
