Hmm. Low HP?
I'd be more concerned with the torque than the HP. Geez-you're supposed to have flywheel 560lb-ft @2000rpms and the graph is at 275lb-ft!! Something must be wrong.
I have a Truck Trend article where the dynoed a Chevy Silverado 1500 with 5.3L and it put down 266lb-ft @ 3000rpms!
I'd take it to a different shop and see if you get a different result. Maybe the operator didn't know what he was doing. I'd be mad as a hornet if any new diesel pickup I bought was putting down under 375lb-ft with the exception of maybe the non-HO Cummins.
Bikenut, The 7.3 stock will dyno right at 200hp...On the 7.3 all the power in the exhaust is in the downpipe..But only about 10-15 dyno...You are attacking the right place first..Guages are not a bad idea first, to set up baseline..And as diagnostic devices..I am thinking my should hit 400hp...I had it dynoed at 260 wo propane or exhaust, or a serious chip...The Fords dont dyno well and you have to have someone who knows the trucks to get them to dyno well...
