Mirror swap
Mirror swap
I just purchased a 2000 SD & was wondering how hard it is to swap out the exterior mirrors. It has the small ones & I need the extendable ones for pulling a TT.
Thanks!
*edit* Nevermind....the search function is a wonderful tool......when you use it.
Thanks!
The little V's moulding pulls right off, top, front of door, above window, the power console on the door pulls up on the one end, and is hindged, unplug wires(they only go one way)...unscrew screw by door handle, remove reflector/light in door, screw there...lift up on door panel and pull towards you...access the wires in the front of the door, three bolts hold the mirrors on, (two people here help) to remount mirrors..10mm?bolts..Reassemble in reverse order...
Did I leave something out????
Done a couple of these before..Easy, took 30 minutes to do the first 10mins to do the other...You can do it....Good Luck..
