turbo monitoring
turbo monitoring
Hey folks. I just purchased a new f250 crew cab 6.0L deisel and was wondering about monitoring the turbo for temp and boost and was wanting some info from those in the know about this stuff. It is my first deisel and I want to take good care of it since it will be the main transportation and the family truckster for long vacations pulling a 31' travel trailer. I have checked out some gauges from different manufacturers but what to monitor and why is the question? Thanks.
turbo boost and temp are not much of a concern in these trucks, now in a little race car like a vw golf tdi built to run that is different but your main concern should more be along the lines of getting the correct spec oil and having it changed according to your driving habits or putting on a bypass filter and having the oil analyzed on a regular basis. for what it is worth many of the vw guys with bypass filters regularly go over 40k between oil changes and get the oil analyzed every 5-7k miles. a boost gage would be easy enough to hook up but in a pulling truck it would just be something extra unless of course you chip the truck and then it might be nice to have to make sure you are not getting too much boost.
If your truck is bone stock, you dont have too much to worry about as the computer keeps close watch on things...
BUT, a good Trans. temp. gauge, Boost and EGT Gauge are always a good thing! Check out www.dieselstop.com for TONS of info. on your truck.
Congrats on the new truck! Enjoy!
If you are towing, I would have guages on mine, I had 6-7000 on mine over the weekend, and with my temp reduction mods I was hitting 180 on the ttrans and 1200 on the turbo temp...which in my opion was right at the limit of the temps...I would get the guages for baseline as well, so you know where you run normally, and then for diagnostic purposes, if you are outside your normal temps...Just me...$600 is little money on a $40000 truck...Good Luck..
