wheels
Tire size should be fine. When you are shopping for wheels keep a couple things in mind. 1st would be the obvious, offset. Make sure you get the proper offset for your truck. 2nd is hubcentric vs lugcentric mountings.
Superduties use a hubcentric wheel design where the weight of the truck on the hubs. The wheel fits snugly on a lip on the hub. If I remember right, the lugnuts are even flat surfaced like a regular nut as opposed to having the taper on one side.
Lugcentric wheels are what most are used to. The vehicle's weight is carried by the lugs.
There have been a few cases where people have had the lugs fail because they bought the wrong type of aftermarket wheels.
