2001 PSD with Auto Tranny Problem
Well, we just got back from the Ford Dealer and with 42K miles the PSD with an automatic transmission lunched the transmission today. My understanding is the intermediate clutches in the tranny went out.
We have pulled a 16 foot trailer about 400 miles over the life of the truck and always with the truck out of overdrive.
Has anyone else experienced this problem?
What was the build date on the truck? From what I've gathered the first 9 months of 01 were built with "slushbox" transmissions. Basically some lower quality parts made it into the mix I think. If you've want more info look over at www.thedieselstop.com
This is the only rebuild trans to get http://www.brianstruckshop.com/
it will never go out no matter what you do to it. Brian has been wrote up in a couple of 4 wheeler magizines his trans are that good.
XS.D>>>>
XS.D>>>>
Well, I picked the truck up today and had a chance to talk with the mechanic who fixed it, sounded as if he really knew what he was doing.
That having been said, he told me that when he pulled the drain plug in the tranny there was so much material that he had to push it out of the way with a screw driver to get the material out of the way so that he could drain the fluid.
He indicated that a needle pack was never installed by Ford and that is what caused all of the trouble, second gear clutch pack, third gear clutch pack, new planitary gears, new needle bearings, etc.
Ford picked up the repairs, and I am grateful for that, but I have one question --- why was there no metal in the pan when they changed the transmission fluid at the same dealer at 34K miles?
Why did the transmission lunch in 7K miles after they serviced it??
