F350 Fourum
First off, what the heck is yawll??? I know about ya'll, but yawll I don't think is even a word.
Anyways what you're asking about will never happen here. There is next to no difference between the F250 and F350, especially when you get up into the Super Duty lines. With the 80-85 they were pretty much the same with the exception of slightly heavier springs on the F350. Then from 86-97 they had a D60 front axle and heavier springs again so no appreciable difference there. Then after the SD came out the difference was about the same as it was during the 80-85 years. The biggest F350 difference after 99 was in the DRW that got a D60 when all the other SD got a D50. Anyhow they're basically the same truck so your forum won't ever happen, and honestly it seems like a waste given how similar the 3/4 and 1 ton trucks are.
