New Diesel Owner
![Thumbs up](https://www.f150online.com/forums/images/icons/icon14.gif)
Well I just signed the papers to bring home a 2002 F350 7.3 Crew Cab. This will be the first diesel I've ever owned, and I'm wondering if there is anything in particular I need to be prepared for. The truck will be used to pull a stock trailer occaisionally (already has the gooseneck ball in it). What should I be ready for in terms of maintenance, etc etc?
Thanks!
Thanks!
For the maintenance side you will want to do a few things specific to diesel engines. If you're keeping the green coolant you need to monitor the SCA (supplemental coolant addative) level in the coolant. This is done with a test kit you can get at an International/Navistar dealer. If you want you can opt for a very complete flush and switch over to gold coolant. Most go with Zerex brand for this and this does not require SCAs to be added and is good for 100,000 mi. For the oil you have a couple options. You can do a standard change interval at 5000 mi @ 14qts/change. This gets somewhat expensive. The other option you have is to install an oil bypass filtration system. If you buy the premade kit for about $100-180 or do a DIY kit for about $50. This will let you run longer change intervals, but will require you to do an oil analysis at regular intervals to make sure the oil is not breaking down between changes. This though would be a good idea no matter the change interval. Those are the main things but there are some other things that will assist in maintenance. The first is a coolant filter. This will help pull out all the silicates that are in the SCAs and will dramatically increase water pump life as the rest of the coolant. Thse are about $60 for the premade kit. The other this is a trans bypass filter. This will help stop any foreign material that may try and make its way into the trans pump if the TC lets go. It will also help increase fluid life as well as reduce temps. This last thing is only in the case of auto transmissions. But those things will help your truck live a longer and healthier life.
