F-250 / Super Duty / Diesel
Transmission temp guage
Old 06-14-2000 | 12:40 AM
GP1200AJ's Avatar
Question Transmission temp guage
Can anyone give me some pointers on installing a transmission temp guage on my 99 F350 auto.
AJ
Old 06-14-2000 | 05:32 AM
V10 man's Avatar
Post
look here:
https://www.f150online.com/f150board...ML/000240.html
I'm doing this same install this weekend. cphilip did a great job. I'm sure he'll be along shortly to give you more info.
Old 06-14-2000 | 08:11 AM
cphilip's Avatar
Post
Am I that predictable V10 man? Good luck on you install. Let me know if you run into any problems. It's really easy. Suprised me.
Here's some more home work for you GP1200AJ. Then we will be gald to accept questions:
http://forums.ford-diesel.com:8080/u...ML/001852.html
http://www.ford-diesel.com/contents/...on%201999%20SD
https://www.f150online.com/f150board...ML/000471.html
2000 F-250 Super Duty, SuperCab XLT, Oxford white with medium grey cloth captains chairs, 5.4L Triton V8 (260 HP - 345 FP Torque version!), 4R100 4 Speed Automatic Transmission, 4 wheel ABS, Deluxe Aluminum Wheels, Trailer Towing Package, Class IV Hitch, Reece load distribution system, Escort Sensor II Electronic Brake controller, Sure Stop towing skirt, "Westin" black powder coated step bars, "White-White" head lamps, Herculiner bed liner, ISSPRO Tranny Temp Guage, Excursion center console, Ford moulded mud gaurds, K&N Air and Oil filter, Amsoil XL7500 5W-30,Air filter minder.
Old 06-14-2000 | 02:53 PM
GP1200AJ's Avatar
Post
Thanks for the links guys, looks pretty easy. I'll let you know how it turns out.
AJ
Old 06-15-2000 | 02:24 AM
V10 man's Avatar
Thumbs up
My guage came in today so I had to install it! This is a simple job. If you can squeeze a wire crimper you're qualified. I'd just like to add a couple comments.
1) If you are planning on installing it in the lower dash, to the right of the steering column(like in cphilip's pics), make sure you posistion the guage as far to the right as you can. There is a dash support bracket that will interfere with the left mounting bolt of the guage. I had to notch mine to clear the bolt.
2) I used the illumination feed wire(brown) to power the light. The light is too bright for me. I'm either going to find the dimmer wire or install a resistor of some sort. The light also bleeds into the factory guage pod. Apparently there is a small gap between the plastic surround and the front of the gauges. The area where the tach is is illuminated slightly. There is also a reflection of the lit guage on the top of the windshield. Another reason to dim the light a bit.
3) I tried to install the sender without any type of sealer so I'd have a good ground. It would not stop leaking. I ended up using 3-4 wraps of Tefflon tape. I only taped the upper half of the sender so the bare bottom half would ground. It worked.
I was able to use my regular drill with the hole saw by turning the steering wheel so the large opening on the top was on the side. Drill fit through there no problem.
cphilip,
I just want to say thanks for posting your idea. I owe you a cold one.
Old 06-15-2000 | 04:30 AM
GP1200AJ's Avatar
Post
I'm (hopefully) Going to install mine tomarrow. I'm going to use a POD instead of drilling my dash(I kinda like the way the pods look on the driverside cab support.) hopefully my parts dealer has the pod in stock, i know he has the guage.
Thanks again for all the help
AJ
Old 06-15-2000 | 10:33 AM
cphilip's Avatar
Post
Good to hear V10 Man! I am always up for a Cold one.
Good advice on that positioning thing. I guess I just got lucky and missed it. But I looked and you are right I was very close to that support. Another 1/8 inch and I would have had the same problem. You will save someone else a problem from that post. Yep I have never had any luck preventing leaks without something in there. Let us know you temps when you start working with it.
I am still debating the illumination thing myself. I presently am just taking it from a 12V switched source. I am also looking at replacing the yellow/white bulb that came with it with a green bulb or bulb cover. To better match OEM green guages and I think it will tone it down as well. You might want to think about trying that first. But if not, there are several ways to get to the dimmer switch wire.
Old 06-15-2000 | 03:03 PM
F250NUT's Avatar
Post
GP1200AJ,
I had to install mine on the a-pillar - I just couldn't force myself to cut a hole in my dash (I'd probably mess it up). I love the location. Good luck!
1999 F250SD, XLT, 4x2, SC, V10, 4.30, LT235x85x16R, Longbed, Diamond plate mud flaps,Trailer tow Pkg, Class IV hitch, Camper special, sliding rear window, rear privacy glass, Ford rain gutters, Line-X, Lund bug deflector, Banks Trans Command, Banks tranny temp guage with Auto Meter single guage pod, B&M Supercooler, Reese 15K fifth wheel hitch
Old 06-19-2000 | 12:55 AM
V10 man's Avatar
Post
I was at the local Auto Zone and saw some colored bulbs. I might try a blue one. I need to take out the clear one and match it up. I was also thinking about finding the dimmer wire that goes to the radio and tappin into that.
Driving around town, with 105 + degree days, I've seen the temp move up to the 150's. Tis past weekend, I took a trip to the mountains and the temp stayed at 140 or lower. I'll be towing my TT over the 4th. I'm really curious to see what it does then.
Old 06-19-2000 | 08:35 AM
cphilip's Avatar
Post
I found the Green guage bulbs at Wally Mart Saturday. 194G made by GE. A two pack was $2.97. I'll let you know how they do.
The DIS site has a good explanition of how to get to the dimmer wire in the light switch. I also heard it ran right by the customer access bundle in the Super Duties, I guess going to the Radio. To make matters confusing it is supposed to be a blue wire with red stripe if I remember correctly. Similar to the 12V switched wire in the bundle.
Old 06-19-2000 | 09:32 PM
GP1200AJ's Avatar
Question
OK Guys, I installed the guage(very simple install). Now I am wondering what your getting for temps. Mine averages 140 to 150 lite. This past weekend I pulled my 5er and jetskis,(I'm guessing a little under 10,000 pounds) outside temp was around 85 and the tranny temp was 170 on the flats and 180 or a little higher on the bigger hills. Is this normal?
AJ
Old 06-20-2000 | 10:56 AM
cphilip's Avatar
Post
Yes that is about normal. The Shop Manual say the normal operating temperture for the 4R70W and the 4R100 is 140 to 170 degree's as that is when they suggest you check the fluid at those temps. High's I have seen so far has been 170 or so towing. Regular 140 to 150 just like you are seeing
By the way I am close to finishing my install of a 12V Cooler Fan on my OEM Auxiliary Tranny cooler in my F250SD. Here are some pictures of that process so far:
Some more here:
http://albums.photopoint.com/j/Album...3146&a=6836646
[This message has been edited by cphilip (edited 06-20-2000).]
Quick Reply: Transmission temp guage
