Does any body know if you can install the security keypad onto a Lariat Superduty. Like the Excursions? Since they have the same doors, hopefully they have the same wiring.
thanks
Although I'm sure it can be done, don't count on the wiring being there. Ford is pretty good at using the least amount of resources possible. There's even a special code on the build sheet to tell which harness to use in the door.
