STEERING/BRAKING PROBLEMS
Does anybody have this problem.
The steering wheel will not turn when you press on the brake?
I seen a few post in Ford Truck Enthusiasts http://www.ford-trucks.com/ If you did see them. I would go and check them out.
I've read of this problem, must have been over on the diesel-ford board. It sounds like a real safety problem but I believe Ford says their usual quote "normal operation". I guess when you're making that u-turn in the road and some idiot tries to pass you that instead of using the brake and turning away from him, you will just have to hit the guy and tell the cop that it's "normal operation"!!!
2000 F250 Crew Cab 4x2 6 speed Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, mud flaps
Trailer tow Pkg, Class IV hitch, sliding rear window, running boards
rear privacy glass, 265/75/16 AS OWL tires, am/fm/cassette/cd
Clarion APA 5240 amp
It is a known problem and Ford doesn't have a fix yet. Most noticed at a stop and the faster you are rolling the less problem there is. It does make parking a big trailer so much fun.
1999.5 F250 SuperDuty, XLT, PSD, SC, shortbox, 4X4offroad, Deep Wedgewood blue, 3.73 LS, 4R100 with PTO, Grey Rhino-liner, Retrax retractible hardtop, camper, tow, Lariat wheels, 295/75/16KO BFG AT, power TT mirrors, power seat, privacy slider, K&N airfilter, Clarion CD/EQ/DSP, soundstream/PPI amps, JL/Boston speakers, and...
I've heard that there is a Ford Technical Service Bulletin, #99-25-8, out on this problem. It involves contaminated power steering fluid. First they try to clean the fluid and if that doesn't work, replace the power steering pump and/or hydroboost. These are not cheap parts, but they are covered under the standard warranty.
The problem only seems to be on the PSD trucks due to the fact that the power steering pump is also used for the brake boost. The gas trucks still use the vacuum boost system.
1999.5 F250 SuperDuty, XLT, PSD, SC, shortbox, 4X4offroad, Deep Wedgewood blue, 3.73 LS, 4R100 with PTO, Grey Rhino-liner, Retrax retractible hardtop, camper, tow, Lariat wheels, 295/75/16KO BFG AT,heated tele power TT mirrors, power seat, privacy slider, K&N airfilter, Clarion CD/EQ/DSP, soundstream/PPI amps, JL/Boston speakers, and...
Autotech
How do you tell if you have hydroboost? I've heard from a few people the gas engines just have vacuum boost but the diesel f-250 and f-350's have the hydroboost system. I also think I read all the F-450's and F-550's have hydroboost. I have the 99 F-250 SD with the V-10 and it has a vacuum booster.
The best information I have, at this time, is that:
all Super Duty Diesels, Super Duty F-450 and F-550 with gasoline engines, have the hydroboost system.
Just check at the rear of your master cylinder; if the booster has got hydraulic lines going to the power steering pump, its a hydroboost.
<font face="Verdana, Arial" size="2">Originally posted by 2hi4u:
I seen a few post in Ford Truck Enthusiasts http://www.ford-trucks.com/ If you did see them. I would go and check them out.</font>
If any one else has this problem let me know what you done to repair.
I have a 2000 F-250SD w/ V-10 and also have the problem...
Dealer Service manager first said it was due to steering geometry of SD and was "normal"... When I took the truck in for the trans cooler TSB the service writer said it was a Ford problem and there was no fix "yet"...
It's a giant "pain" when trying to back my 27' TT and I spend a fair amount of time in the Smoky's... Recently while trying to back out of a friends rather steep narrow driveway I almost went off the #$@!#$ side of the mountain because I couldn't turn the #$@%! steering wheel with the brake applied... It's a dangerous condition and it needs to be fixed!!! I filed a complaint (notice) with NHSTA via their online form... I urge others to do the same...
Best Regards,
Les
2000 F-250 Super Duty XLT
4X4 Off Road, SWB, Super Cab, V-10/4R100/3:73LS
Best Regards,
Les
i have been asking around to local superduties owners, and so far all have had that problem. i have a V-10 with a plow on it and i thought maybee it was the weight of the plow doing it, but after removing the plow it still does it. i have over sized tires also but i dont think that is the problem either. i havent had any problems when i am rolling just at a dead stop it wont turn.....
2000 F-250 SuperDuty SC,SB,4x4, 6.8L V-10 auto.3:73 gears, SUPERCHIP, Tech style tonneau cover, back country chrome step bars, Goodyear 305x70x16 ATS tires www/angelfire.com/rock/nFiredude/Firedude26's
Intersting, I've a 99 F250 SD V10 and just finished looking as 'autotech' suggested - and no lines - other than the two normal fliud lines going to the brakes. Maybe someone knows what configurations have hydroboost or not.
1999 F250SD, XLT, 4x2, SC, V10, 4.30, LT235x85x16R, Longbed, Diamond plate mud flaps,Trailer tow Pkg, Class IV hitch, Camper special, sliding rear window, rear privacy glass, Ford rain gutters, Line-X, Lund bug deflector, Banks Trans Command, Banks tranny temp guage with Auto Meter single guage pod, B&M Supercooler, Reese 15K fifth wheel hitch
