battery light on, volt guage maxed out
![Unhappy](https://www.f150online.com/forums/images/icons/icon9.gif)
I've been haveing intermittant problem with the battery light just flashing on briefly. Well today, it came on and stayed on. The volt guage pegged it's self past 18V. The power windows aslo quit working while this was happining. Luckyly I was only a mile or two from home. When I got home, I opened the hood and discoverd that one of the covers had blown off the battery. Prolly boiling from extream overcharging. I hosed off the areas that got acid on them. After about 8 hours, I check the truck again. With the key on, not running the volt guage was in the normal range. I got brave and started the truck. All was OK again. No battery light, volt guage normal.
I know I need to get this in the shop ASAP. What I was wondering is 1) As long as this doesn't happen again, do you think I could drive the 20 miles to the Ford dealer? 2) Do you think it's possible to disconect all the wires to the altenator and drive it that way the 20 miles? I know in the old days you could get by without the alt. for short distances, the battery supplying all the power. Thanks for any help!
![Post](https://www.f150online.com/forums/images/icons/icon1.gif)
Call your dealer and ask them if its safe to drive. If the answer is NO, then then I bet that Ford would pick up the towing costs if your still under warranty..
They should also replace anything that was damaged in the process.
I see we visit all the same boards as I've see your question about 3 other places as well..
Y2K F250 XLT SC 4x2 5.4L 5sp 4.10LS
Check all the wires on the engine. Don't give them the opportunity to blame the header install. Then call the roadside assistance people and have your truck towed (flat-bedded) into the shop. No reason to risk injury to yourself or make things worse.
R Bess-
Yeah, there aren't but a couple of good sites & we're all over 'em.
R Bess-
![](https://www.f150online.com/f150board/smile.gif)
