F-250's throttle
This isn't going to be as much help as you're looking at an 05, but the principal may transfer over. On the 99-03 SD trucks with the PSD you can make a modification to the pedal assembly to take out the dead spot at the begining of the pedal movement. It makes the pedal add throttle right from the start of movement. There really isn't any way to change things after that, but it does help. You can read about how to do it here
Originally posted by DrkShadow
That kinda sucks. I wonder how much the tuners actually improve the response.
