problem with my F-250, hose hanging loose
Hi,
I have 2004 F-250 Supercab XLT, short bed. I was trying to wash the undercarriage Today and found this hose hanging loose from driver's side rear end. Could someone tell me what this hose is for and where it should be mounted? I don't think it should be hanging loose like that. Don't like to go to the dealer so please help me out. Thank you.
Josh
Josh
It's a vent so your rear axle seals don't explode when the oil gets hot. The loose end is typically secured up on the frame or underside of the bed somewhere. Looks like it may have been knocked loose by the spare tire or perhaps when the shocks were changed. If the clip is broken, just use a zip tie to secure it up out of the way somewhere. The only reason it's up high is to keep water from getting in the axle if you go through deep water.
Don't plug off the end. It's a vent, it needs to breathe. Otherwise pressure can build up inside the axle when the fluid gets hot and it will blow out the weakest point. It is located up high to keep it away from water and mud. It's on a flexible tube so it can move as the axle moves up and down.
I just went out and looked at mine and it is routed up into a hole in the bed subframe crossmember directly above the axle.
