Brake Question, 1999 F250
I have a 1999 F250 SD, 4wd, 5.4L, automatic, std. cab., single wheels (rear). I need to purchase front rotors. I have 4 wheel disc. brakes. How do I determine if this truck has a monobeam axle? How do I determine if I have 4 wheel anti-lock brakes? These are questions the parts store asks. The brake code in the door jamb lists the number 2. The axle code is C2. The production date is 3/98. Thanks for any help.
You have a 4x4 SD so you have a solid axle (monobeam). As for if you have 4wheel abs check to see if you have wires running to your front bearing assemblies. They should be able to put in either and get the same part number. The rotors are the same, the only difference is the early to late 99 trucks. Make SURE that you tell them your build date as there is a split around 3/22/99 build date trucks.
