What the hell!?!
What the hell!?!
I have a '99 SD w/ the 5.4L V8 and when the truck is idling it is fine for a few seconds but then the motor sounds like it is about to cut off. Watching the tach. it shows the motor droping down to about 400-500 rpm's for a few seconds then jumping back to normal. What the hell is going on?
Idle Air Control Valve...probably
This valve allows air past the throttle body during idle. It is likely that this needs cleaned or replaced. If it almost stalls and then recovers, this valve might just be dirty.
Ooops, I am sorry, I should have read on. It is not allowing me to delete.
