Help finding 12volt switched ignition
I've probed the only red wire w/yellow tracer and am getting nothing, so I went ahead and tapped it with a 6inch wire just to be sure I'm getting a connection and still no power when the ignition is on? Is there another wire to look for as I've probed all sorts of connections and can't find the switched ignition. I have an 06 F-250. Perhaps the tap did not break the plastic sheathing? Can I be sure that the red w/ yellow tracer is switched ignition? If so I will hook up gauges. I did find the dash lighting with no probs so I know my meter is working.
Thanks for any help
Scott
Thanks for any help
Scott
