6.0 PowerStoke Programmer Help!
Hopefully this works!http://opion.site5.com/~dieselta/product_info.php?cPath=26&products_id=30
right now everyone is lovin the SCT Xcal2, it doesnt kill the check book or the tranny, and can be custom tuned to whatever you need. check out thedieselgarage.com they have everything you want to know about tuners. but if you get a tuner, a new exhaust system, intake, and gauges are highly recommended just fyi.
Superchips
I programmed my 2003 6.0 with a Superchips. Suposedly adds 125-150 hp on the "High Performance" setting. I checked milage between the +90hp "Economy" setting and the +150hp High performance setting and could not tell the difference on plain highway cruising.
The bad thing about the Superchips is that it does not have custom settings, such as adjustable shift points. It just adds a high performance program to the tranny. Also does not adjust speedo for taller tires. It does erase the speed limiter. The speedo just falls to zero while cruising at speeds over 105 mph, then jumps back to correct speed when I slow down below 105 mph.
I am adding MBRP cool duals and AFE Stage II air intake this week. These should help power and mpg.
Cheers
Cheers
Superchips
I just installed the Superchips Flashpaq. This programmer will allow for tire size adjustments and has three tunes as well. It also has internet updateability. The performance tune is plenty powerful while not quite as strong as the other Superchips programmers. However, as far as I know this is the only one that currently will allow for tire size adjustments.
Scott
Scott
Bully Dog
You might want to try Bully Dog they have vey good quality stuff inlcude propane injection systems.
http://www.bullydog.com/
