1999 7.3 F-250 Programmer question
Best intake is a DIY with a Green filter or a PG7 media from AFE. There is no reason to buy a $400 intake for a 7.3L when the same thing can be made for less than $100. Cost may fluctuate some depending on if you have an early or a late 99.
Skip the programmer completely. Instead go to www.dp-tuner.com and give Jody a call. He will set you up with what you need. If you have an automatic I suggest a PMT1 PCM to go with it. The trans shifts are very nice.
