99' 250 Psd???
99' 250 Psd???
As you can see I am new here and I have a question about my 99'.
I know the factory tire size is 235/85-16 and I would like to level the truck and add a larger all terain tire.
What leveling kit or suspension manufacturer can you all recommend and with what tire size?
I would also like to see a few pictures of other PSD's leveled w/ larger tire, so can you direct me to a few pics.
I did try and search the forum and did not come up with much.
thanks,
thanks,
You want to get an Edge mini spring pack. Its the best and most economical leveling kit on the market at the moment. Supposedly some guys are running 315/75/16s (35s) with only a leveling kit, but there was no way they'd fit on my friends 01. We had to do a 4" lift to clear them without moving bumpers and such. IMO I think 305/70/16 on 16x8 wheels (stockers are too narrow) will fill out the wheel wells nicely. My truck I chose to go with the X code springs which are the factory plow package springs which paired with the F350/early 99 SD rear 4" blocks the truck sits level. 305s will fit with no problems and will be what I run when my MTRs wear out.
