VIN Number Breakdown
I'm in the market for a new truck and want to get an '02 or '03 F-250. I am looking for specific options plus I'm used to all the ameneties I have in my '97 F-150. I'm trying to find somewhere that has a listing of all the codes for the F-250 VIN number so that I can identify what options are on the truck when I look at them on the lot (surprisingly the salespeople are not so sure about towing packages, gear ratios, brake systems, etc.). I have the shop manual for my F-150 which lists every possible code option but that doesn't help me with the 250's. If anyone can point me in the right direction I would greatly appreciate it.
Here's the VIN Decoder Info
but it won't tell you all the options a truck has. You'll also need to check the door sticker (Info posted separately), between the two, most everything is covered! Good luck in your search
VIN NUMBER:
The first three vehicle identification number (VIN) positions are the world manufacturer code.
1FD Ford Motor Company, USA, incomplete vehicle
1FM Ford Motor Company, USA, multi-purpose vehicle
1FT Ford Motor Company, USA, truck, completed vehicle
2FM Ford Motor Company, Canada, multi-purpose vehicle
3FD Ford Motor Company, Mexico, incomplete vehicle
The fourth VIN position is the vehicle brake type and GVWR code (all vehicles use hydraulic brakes).
N 8,501-9,000 pounds GVWR with driver and front passenger air bags
S 9,001-10,000 pounds GVWR with driver and front passenger air bags
W 10,001-14,000 pounds GVWR with driver and front passenger air bags
X 14,001-16,000 pounds GVWR with driver and front passenger air bags
A 16,001-19,500 pounds GVWR with driver and front passenger air bags
H 8,501-9,000 pounds GVWR, without air bags (Mexico)
J 9,000-10,000 pounds GVWR, without air bags (Mexico)
K 10,001-14,000 pounds GVWR, without air bags (Mexico)
L 14,001-16,000 pounds GVWR, without air bags (Mexico)
M 16,001-19,500 pounds GVWR, without air bags (Mexico)
Positions 5 through 7 indicate vehicle line, series and body type.
F20 F-250, Regular Cab, 4x2, single rear wheels
X20 F-250, SuperCab, 4x2, single rear wheels
W20 F-250, Crew Cab, 4x2, single rear wheels
F21 F-250, Regular Cab, 4x4, single rear wheels
X21 F-250, SuperCab, 4x4, single rear wheels
W21 F-250, Crew Cab, 4x4, single rear wheels
F30 F-350, Regular Cab, 4x2, single rear wheels
X30 F-350, SuperCab, 4x2, single rear wheels
W30 F-350, Crew Cab, 4x2, single rear wheels
F31 F-350, Regular Cab, 4x4, single rear wheels
X31 F-350, SuperCab, 4x4, single rear wheels
W31 F-350, Crew Cab, 4x4, single rear wheels
F32 F-350, Regular Cab, 4x2, dual rear wheels
X32 F-350, SuperCab, 4x2, dual rear wheels
W32 F-350, Crew Cab, 4x2, dual rear wheels
F33 F-350, Regular Cab, 4x4, dual rear wheels
X33 F-350, SuperCab, 4x4, dual rear wheels
W33 F-350, Crew Cab, 4x4, dual rear wheels
F34 F-350, Regular Cab (Chassis Cab), 4x2, single rear wheels
X34 F-350, SuperCab (Chassis Cab), 4x2, single rear wheels
W34 F-350, Crew Cab (Chassis Cab), 4x2, single rear wheels
F35 F-350, Regular Cab (Chassis Cab), 4x4, single rear wheels
X35 F-350, SuperCab (Chassis Cab), 4x4, single rear wheels
W35 F-350, Crew Cab (Chassis Cab), 4x4, single rear wheels
F36 F-350, Regular Cab (Chassis Cab), 4x2, dual rear wheels
X36 F-350, SuperCab (Chassis Cab), 4x2, dual rear wheels
W36 F-350, Crew Cab (Chassis Cab), 4x2, dual rear wheels
F37 F-350, Regular Cab (Chassis Cab), 4x4, dual rear wheels
X37 F-350, SuperCab (Chassis Cab), 4x4, dual rear wheels
W37 F-350, Crew Cab (Chassis Cab), 4x4, dual rear wheels
F46 F-450, Regular Cab (Chassis Cab), 4x2
W46 F-450, Crew Cab (Chassis Cab), 4x2
W42 F-450, Crew Cab (with box), 4x2, dual rear wheels
W43 F-450, Crew Cab (with box), 4x4, dual rear wheels
F47 F-450, Regular Cab (Chassis Cab), 4x4
W47 F-450, Crew Cab (Chassis Cab), 4x4
F56 F-550, Regular Cab (Chassis Cab), 4x2
W56 F-550, Crew Cab (Chassis Cab), 4x2
F57 F-550, Regular Cab (Chassis Cab), 4x4
X46 F-450, SuperCab (Chassis Cab), 4x2
X47 F-450, SuperCab (Chassis Cab), 4x4
X56 F-550, SuperCab (Chassis Cab), 4x2
X57 F-550, SuperCab (Chassis Cab), 4x4
W57 F-550, Crew Cab, (Chassis Cab), 4x4
U40 Excursion, 4x2, XLT
U41 Excursion, four-door, 4x4, XLT
U42 Excursion, four-door, 4x2, Limited
U43 Excursion, four-door, 4x4, Limited
The eighth VIN position is the engine displacement and number of cylinders.
L 5.4L, Modular, SOHC, EFI, V8, Gas
S 6.8L, SOHC, EFI, V10, Gas
F 7.3L, OHV, DI Turbo, V8, Diesel
Z 6.8L, gaseous fuel prep (F-Series)
D 6.8L, propane only (F-Series)
B 5.4L, propane only (F-Series)
The ninth VIN position is a government assigned, computer-generated check digit.
The tenth VIN position is the model year code.
· 2 2002
The eleventh VIN position is the assembly plant code.
S Allen Park (Allen Park, Michigan)
E Kentucky Truck (Jefferson County, Kentucky)
M Cuautitlan (Cuautitlan, Mexico)
The last six VIN positions are an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
· A0000-E99999 Ford Division
VIN NUMBER:
· 2 2002
Vehicle Certification Label Part 1
VEHICLE CERTIFICATION LABEL:
Exterior paint codes may be listed as a two-part code. The first set of characters listed indicate the vehicle primary body color code. The second set of characters listed (if applicable) indicated a two-tone or accent body color code.
AQ Arizona Beige (clear coat), F-Series
CX Dark Shadow Gray (clear coat), F-Series
F1 Vermilion Red (clear coat), F-Series
FN Dark Toreador Red, F-Series
L2 True Blue (clear coat)
LR Sapphire Blue (clear coat), F-Series
PY Highland Green (waterborne), F-Series
UD Ebony, F-Series
Z1 Oxford White (clear coat), F-Series
Z3 Silver Metallic (clear coat), F-Series
Wheelbase
137 137-inch wheelbase (F-Series, Excursion)
141 141-inch wheelbase (F-Series)
142 142-inch wheelbase (F-Series)
156 156-inch wheelbase (F-Series)
158 158-inch wheelbase (F-Series)
162 162-inch wheelbase (F-Series)
165 165-inch wheelbase (F-Series)
172 172-inch wheelbase (F-Series)
176 176-inch wheelbase (F-Series)
189 189-inch wheelbase (F-Series)
200 200-inch wheelbase (F-Series)
201 201-inch wheelbase (F-Series)
Brake Type
B Four-wheel anti-lock brakes system (ABS)
Interior trim codes are listed as a two-part code. The first character listed identifies the trim type. The second character listed identifies the interior trim color.
Interior Trim Type
K Knitted vinyl bench seat, F-Series
C Cloth bench seat, F-Series
F Cloth captains chairs, Excursion
F Flight bench seat, Mexico sold F-Series XLT only
G High back cloth individual seats, F-Series
H High back knitted vinyl individual seats, F-Series
J High back vinyl individual seats, F-Series
3 Cloth 40/20/40 seats, F-Series/Excursion
D Cloth 40/20/40 seats with integrated restraints, F-Series
8 Leather 40/20/40 seats, F-Series
9 Leather 40/20/40 seats with integrated restraints, F-Series
2 Cloth captains chairs, F-Series
6 Cloth captains chairs with integrated restraints, F-Series
4 Leather captains chairs, F-Series/Excursion
7 Leather captains chairs with integrated restraints, F-Series
5 Leather quad captains chairs, F-Series
L Leather captains chairs, Excursion Limited
B Leather captains chairs with vinyl rear bench, F-Series
MCloth 40/20/40 seats with rear bench mono. F-Series
PLeather captains chairs with vinyl rear bench, F-Series
Interior Trim Color
H Medium Parchment, F-Series
E Medium Flint, F-Series/Excursion
BEbony, F-Series
DDark Flint, F-Series
Tape/Paint Stripe (TP/PS)
D Light Argent/Medium Platinum/Light Argent, F-Series XLT
E Arizona Beige/Dark Sandalwood/Arizona Beige, F-Series
F Wild Strawberry/Dark Shadow Gray/Wild Strawberry, F-Series
Radio Type
7 AM/FM stereo with clock, F-Series
G Delete AM/FM stereo with clock, all other components installed, F-Series
9 AM/FM stereo with cassette and clock, F-Series/Excursion
R Delete AM/FM stereo with cassette and clock, all other components installed, F-Series
K AM/FM stereo with cassette and compact disc player, F-Series/Excursion
Y Delete standard AM radio with clock, F-Series
1 AM/FM stereo with cassette and in-dash six disc compact disc (CD) changer, F-Series/Excursion
UD Ebony, F-Series
Wheelbase
Brake Type
Interior Trim Type
Interior Trim Color
BEbony, F-Series
Radio Type
Vehicle Certification Lable Part 2
I had to separate as the post exceeded the maximum size allowed.
Axle Type
31 3.73 non-limited slip, F-250/Excursion
C1 3.73 limited slip, F-250/Excursion
32 4.10 non-limited slip, F-250
C2 4.10 limited slip, F-250/Excursion
33 4.30 non-limited slip, F-250
C3 4.30 limited slip, F-250/Excursion
36 4.56 non-limited slip, F-250
C6 4.56 limited slip, F-250
41 3.73 non-limited slip, F-350 (single rear wheels)
D1 3.73 limited slip, F-350 (single rear wheels)
42 4.10 non-limited slip, F-350 (single rear wheels)
D2 4.10 limited slip, F-350 (single rear wheels)
43 4.30 non-limited slip, F-350 (single rear wheels)
D3 4.30 limited slip, F-350 (single rear wheels)
46 4.56 non-limited slip, F-350 (single rear wheels)
D6 4.56 limited slip, F-350 (single rear wheels)
61 3.73 non-limited slip, F-350 (dual rear wheels)
F1 3.73 limited slip, F-350 (dual rear wheels)
62 4.10 non-limited slip, F-350 (dual rear wheels)
F2 4.10 limited slip, F-350 (dual rear wheels)
63 4.30 non-limited slip, F-350 (dual rear wheels)
66 4.56 non-limited slip, F-350 (dual rear wheels)
F6 4.56 limited slip, F-350 (dual rear wheels)
81 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 4.30 limited slip, F-450 Chassis Cab
73 4.30 non-limited slip, F-450 Chassis Cab
78 4.88 non-limited slip, F-450 Chassis Cab
G8 4.88 limited slip, F-450 Chassis Cab
75 5.38 non-limited slip, F-450 Chassis Cab
G5 5.38 limited slip, F-450 Chassis Cab
GW 4.10 limited slip, F-450 Chassis Cab
98 4.88 non-limited slip, F-550 Chassis Cab
K8 4.88 limited slip, F-550 Chassis Cab
95 5.38 non-limited slip, F-550 Chassis Cab
K5 5.38 limited slip, F-550 Chassis Cab
KW 4.10 limited slip, F-550 Chassis Cab
Transmission Type
E Four-speed automatic overdrive (4R100), gasoline engines, F-Series/Excursion
9 Four-speed automatic overdrive (4R100), diesel engine, F-Series/Excursion
6 Six-speed manual, Dana ZF (M6HD-6), F-Series
5 Six-speed manual, F-Series (5.4L, 6.8L Gas)
2 Five-speed manual, F-Series (5.4L, 6.8L Gas/LPG), Mexico only
Springs
Springs codes are listed as a two-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs F-Series
Base part number 5310 (RH/LH)
Pre-fix F81A
B Suffix BA
C Suffix CA
D Suffix DA
E Suffix EA
F Suffix FA
G Suffix GA
H Suffix HA
I Suffix RA
J Suffix SA
K Suffix TA
L Suffix UA
Pre-fix 1C34
S Suffix AAA
T Suffix ABA
U Suffix ACA
V Suffix ADA
W Suffix AEA
X Suffix AFA
Front Springs Excursion
Pre-fix YC35
G Suffix G
H Suffix H
S Suffix S
Pre-fix 1C34
AG
AH
AJ
Rear Springs F-Series
L Rear air suspension
B 1C34-5560-CB, F-250, F-350
C 1C35-5560-DB, F-250, F-350
D YC35-5560-EA, F-250, F-350
M YC35-5A975-AA, F-450, F-550
N YC35-5A975-BA, F-450, F-550
Auxiliary Springs F-Series
A YC35-5588-A (wide frame)
D F81A-5588-D (narrow frame)
Rear Springs Excursion
Base part number 5560 (RH/LH)
Pre-fix YC35
A Suffix A
Pre-fix 1C34
B Suffix B
You may also want to check out this site... It has a fairly active SD forum.
http://www.ford-trucks.com/
Axle Type
Transmission Type
Springs
Pre-fix F81A
B Suffix BA
C Suffix CA
D Suffix DA
E Suffix EA
F Suffix FA
G Suffix GA
H Suffix HA
I Suffix RA
J Suffix SA
K Suffix TA
L Suffix UA
Pre-fix 1C34
S Suffix AAA
T Suffix ABA
U Suffix ACA
V Suffix ADA
W Suffix AEA
X Suffix AFA
Pre-fix YC35
G Suffix G
H Suffix H
S Suffix S
Pre-fix 1C34
AG
AH
AJ
Pre-fix YC35
A Suffix A
Pre-fix 1C34
B Suffix B
