F-250 / Super Duty / Diesel
Fully boxed frame
Old 05-05-2007, 09:43 PM
JohnBoy88's Avatar
Fully boxed frame
Ford has been making a huge deal about the F-150's fully boxed frame (even though all the other trucks have it too). I was wondering why the super duties do not have a fully boxed frame. It seems logical....
Here is an '08 F-450 super duty:
Old 05-05-2007, 09:53 PM
Administrator
Contributor
Super Moderator
I really cant see very much in that pic... Are you sure that its not actually, fully boxed, just not a ladder frame?
Old 05-05-2007, 09:56 PM
JohnBoy88's Avatar
If you look at the area of the pic "under" the driveshaft you can see the cables that run along the inside of the frame on the driver's side. It's just like the frame on my truck, which is not fully boxed.
Old 05-05-2007, 09:58 PM
Administrator
Contributor
Super Moderator
those are fuel lines, and looks to me like its on the outside of a fully boxed frame rail... let me see what other pics i can find to help prove you wrong
Old 05-05-2007, 10:01 PM
JohnBoy88's Avatar
Ooh, no need, my bad. I thought the fuel lines were recessed in the frame like mine (I remember because that's where my fuel filter is located). But now that I look closer I see the bottom of the frame and I think it is fully boxed....
But pics would be great.
Old 05-05-2007, 10:02 PM
Administrator
Contributor
Super Moderator
Doh, you win https://www.f150online.com/forums/sh...highlight=rust
Oh well it definetly looks thicker, and much stronger then my frame does
Old 05-05-2007, 10:04 PM
JohnBoy88's Avatar
Aww man I conceded way too early!
Doesn't that seem odd that it's not fully boxed? Isn't that supposed to help a lot?
Old 05-05-2007, 10:08 PM
Administrator
Contributor
Super Moderator
hahah yea well i came on a little strong without knowing all the facts
But yah full boxed frame helps with twisting, and impacts, but adds weight. My best guess is that if the truck is over a certain weight (4dr dualie) then they either have to pay more to make them, or the consumer has to pay more to register it etc...
So simple answer is i bet it has to do with the truck would be too heavy with a fully boxed frame
Old 05-05-2007, 10:10 PM
JohnBoy88's Avatar
Hmm... well that's good enough for me.
Old 05-05-2007, 10:28 PM
Administrator
Contributor
Super Moderator
If you're happy im happy
Old 05-06-2007, 12:10 AM
freekyFX4's Avatar
I know that the front end frame rails are fully boxed on the new Super Duty. The ones under the bed are not. It's strange that they did not fully box the full length of the frame. I also know that the frame rails are much thicker on the Super Duty.
Old 05-06-2007, 05:07 PM
CajunJosh's Avatar
I dont know if this was discussed on this board or thediselstop but it seems that they dont fully box the frames because it would make the truck too ridged. Due to the higher weight raitings/capacities of the super duty trucks the frames need to bend/flex slightly under exterme loads.
Old 05-06-2007, 05:33 PM
Lumadar's Avatar
You basically got it.
With 1/2 ton trucks the powertrain and suspension are the limiting factors for towing. they can only go so high, where as with the super Duty trucks, Big rigs etc, they have much heavier suspensions and larger powertrains. On the smaller trucks having a rigid frame adds stability when towing, and due to the powertrain limiting max weight possibilities it becomes an advantage. When you go to a Super Duty truck if you had a fully boxed frame dealing with the 15,000-24,500 pound loads it would have too much stress on individual points due to a lack of flex in the frame- causing them to snap or break.
Old 05-06-2007, 11:45 PM
JohnBoy88's Avatar
That makes sense.
Old 05-14-2007, 08:38 PM
Pagnew's Avatar
Good explaination Lumadar!...especially when pulling heavy trailers / equipment in an off-road situation. I've never seen any big rig - 4X2 or 4X4 with a fully boxed frame. Thats' why for comfort the cabs sit on their own suspension or air-bags because of the flex.
Quick Reply: Fully boxed frame
