F-250 / Super Duty / Diesel
What Diesel Engine Is the Best
Old 07-14-2007 | 02:24 PM
FamilyRide's Avatar
7.3 hasn't been put in a Ford since early '03. The 7.3 had more than it's fair share of problem across the years it was made. The ones still out there running are likely the good ones.
6.0 same deal. I wish I could find the list, but the list I saw showed the 7.3 with almost double the bulletins out that the 6.0 at that time. 6.4 has had early issues but it's still too early to tell.
A friend just traded a '03 Cummins for an '07 with the 6.7. The '03 was a bull, but he says the 6.7 kicks it's @$$ all over the place. It's got the new tranny also.
Close you're eyes and throw the dart.
Old 07-15-2007 | 10:38 AM
crazynip's Avatar
but the 7.3 had 15 years to build up that number, 20 if you consider the 6.9 too
Old 07-18-2007 | 02:38 AM
FamilyRide's Avatar
I thought it would be a given, but I guess not. I'm talking comparable TD's only. Although it's hard to compare the 7.3 to the 6.0 with all the additional electronic controls and EPA crap.
Old 07-18-2007 | 10:27 PM
SuperSport1985's Avatar
Originally Posted by nvrenuff
I have never heard of any issues with the torqueshift tranny, so what makes the allison superior?
Ummm they just are. Torqshift is just a FORD only thing and the Ally has been in many other applications than the Torqshift so I would go with the general concensus and go with the Ally.
Old 07-19-2007 | 12:13 AM
tardman91's Avatar
My brother's 04 F250 with the 6.0 has 99K on it and not a single problem.
Old 07-19-2007 | 01:18 AM
dennisfranz's Avatar
My 01 7.3L only had a cam position sensor go out once. Thats it.
Only 89K though.
Old 07-19-2007 | 02:01 AM
FamilyRide's Avatar
Oh sorry.
I think you'll find that most people that have experience with both will give the Torqueshift the nod. The Allison is a good tranny, but I've heard more people that I know that have them, either complain about them or have problems. The name is what does it. And I don't believe the tranny is the exact tranny used in other applications.
Both good, but TS has an edge.
And no, there is now real problems with them. BTW, when running my tuner, mine will definitely bark both rear wheels in 2nd and sometimes 3rd, easily. It's stock of course. It's solid as can be.
Old 07-19-2007 | 10:10 AM
Zaairman's Avatar
The Allison tranmission. A guy at work had one in his 2003 Chebby 3500 Dmax Dually. 100% stock, and the damn thing would still go into limp mode if he was pulling his huge trailer up a hill and would hit the go pedal. Dealer said it was normal and that the transmission was just sensing that it was getting too much torque. That and the fact that within 40K miles, the truck was on its third set of injectors and second turbos, made him sell it and buy a Dudge Mega cab. He said one way or another, he's making sure that his transmission goes out before the warranty is up..
And FamilyRide, how do you like your Revos?
Old 07-20-2007 | 12:50 AM
Oh sorry.
My only experiance is in the RV world and thy use the Allison MH3000 wich is probably alot better than the Allison MH1000.
Old 07-20-2007 | 01:04 AM
freekyFX4's Avatar
Originally Posted by davidshick2
I have heard no complaints about the 7.3L, but the 6.0 heard alot of bad things about and havnt really heard much about the new 6.4 I am also looking to buy a diesel in about 1-2 years and am going to get an automatic 4x4. I have always driven ford wouldnt buy anything else just looking for some opinions. I will also be using it to tow bobcats at times and dont want anything thats a dog.
The 6.4L PSD is the best. Of course, I am a little prejudiced.
Old 08-07-2007 | 10:36 PM
masone's Avatar
My dad had a 2003 6.0 that did pretty good with a few minor problems, has 120k on it. Now has an 07 KR 6.0 with 15k and it is a bad *** truck, I got him a Bully Dog 40500 for his b-day and he gets 22 MPG on the highway and runs mid 14's in the 1/4, and he absolutely loves it.
Old 08-08-2007 | 11:32 PM
torturekilla's Avatar
Originally Posted by wandell
I think the new Powerstroke and Cummin's are better than the GM Duramax.
you got thing bout what tranny you get with dodge and ford tho.....
chevy has allison tranny ....... which neither ford, or dodge have.........
Old 08-09-2007 | 03:15 PM
93whitelightnin's Avatar
I think you need hooked on phonics
Old 09-07-2007 | 04:13 PM
vycan's Avatar
Hello all,
PSD can indeed get 20+ MPG for highway driving the trick is to keep your RPM's down around the 1800 or less range. That means accepting 63-65 mph as your max cruising speed. My wife's truck is a 97 PSD Crew Cab with a short bed, and Nerf bars, so the truck is packing some extra weight.
We just completed a road trip from Indiana to Alabama and back again this weekend, and had 22 MPG the whole way.
Now, the city MPG is around 16-18.
The things I do to the truck:
I use "V8 Engine restore" in the crank case
Lucas injector cleaner
Changed the air filter housing from stock to a larger cone filter. (down side is it is sucking in hot engine air... perhaps I should try to make a cold air case?)
Change the oil religiously at 3000 miles or three months.
Change the transmission filter annually.
****THIS IS THE MOST IMPORTANT****
We drive around town and on the freeway trying to keep the RPM's around 1500-1800. Yes it means that grandma in a chevette is beating you, but I pay 1/3 less for gas annually than all of you lead foots.
-Vycan
Old 09-07-2007 | 07:05 PM
05_F150's Avatar
7.3 with a tuner with get 18-22 mpg no problem, My dads 03 7.3 with a superchip n k&n drop-in get 21.7 city/highway avg (crew cab long bed lifted on 35s) and has 129k miles nothing but oil n fuel has been replaced on truck.
6.0 liters n 6.4 haul *** but not for long period of time.. 7.3 are slow with stock turbos but will last you forever
