new F250 7.3 owner with questions
Are K & N filters good to put in?
Do I need to get a chip or tuner, if so what is the best?
My truck is a '03 7.2 with 70,000 I just bought it the other day, to pull a camper with. Camper loaded weighs around 7700. Any help or ideas on what I need to do will be greatly appreciated. Thanks
Anything you should do? Change the oil. You'll need 15 quarts. I use Motorcraft 15w40, and a Motorcraft filter, FL-1995. Make sure you prefill the filter (2 quarts). Change out the fuel filter and air filter. Carry a spare CPS ($25 from the dealer) in the glove box, along with a 10MM wrench.
The tuner is up to you, but make sure you have gauges. I'm running an Edge Juice with Attitude.
Oh, and your motor is a 7.3.
Originally Posted by Zaairman
K&N is a good filter to put in if you don't like your turbo.
They don't just stop at the turbo, try the whole engine. The K&N filters allow dirt to get past the filter media in turbo applications because of the higher pressures and wind velocities. This dirt will do some damage to the turbo, but its actually the least of your worries. The turbo could acutally be run like that without any MAJOR issues depending on condition. The problem is the dirt gets into the cylinders and scores the walls causing low compression. A dusted engine would require a complete teardown and rebuild.
I stick with Rotella 15W40 oil, Motorcraft usually sells for a premium price. Rotella can be bought for about $8/gal at Walmart, plus they started carrying it in 5 gallon buckets.
If you want a chip don't just buy some off the shelf module or programmer, none are really that good. I've got 2 trucks at work running Superchips and I used to have the Edge Evolution and the Juice with Attitude. All were pretty much junk. My DP chip is by far the better of the options. You're much better going with a custom chip like this as its taylored to your specific truck, driving habits, and setup for what you're doing with the truck. The big thing is since you have an 03 you have PMRs in it, so cylinder pressures and timing is a huge deal. That is unless you actually like throwing rods through the side of the block. Jody at DP has actually invested the time and money in CP testing, so his programs for the PMR engines are some of the most powerful and safe out there.
Motorcraft 5 quart jugs are $9 at Advance Auto. Cheaper than Rotella...
You can run Amsoil, just make sure that it meets API-CI4 specs. With a PSD oil is more critical than others because of the HEUI injection system. Basically the engine oil is driving your injectors, so be careful with what you pick. The problem with Amsoil for me was always finding a dealer for it, but also their prices weren't all that great. For what marginal gains I saw on the oil in previous trucks and the price it wasn't worth it, so I went back to dino. Its all in what you want to pay.
Contact Jody (owner) at www.DP-Tuner.com. You're best off calling him vs. email. Either Jody or his wife Diane are both very knowledgable and are more than willing to talk you through what you need to know to buy the right chip. Heck even if you just have questions call him. He's never turned anyone away, or failed to help out someone.
Originally Posted by Pagnew
Amsoil is a very good and dependable oil and I have enjoyed it in my gas engines for years!. Hey diesel folks...any info on using this oil in your engines?
Originally Posted by Okieboy
Not sure how true the rumor was last year but I had heard that a truck driver was using amsoil with the premium oil filter(s) and lost the engine and was suing Amsoil. Not sure about it because I googled the information and nothing came about??? I was going to use it but now I'm having 2nd thoughts! That's my 2 cents.
Powerstroke 73 didn't mention anything wrong with it for diesels and he knows quite a bit. Still, I never heard of that rumor.
My 2 cents with a penny on top
