4wd look on a 2wd
4wd look on a 2wd
i am looking at a new 08 sd. i love the look of a 4wd, but have no need for it. what will it take to get a 2wd to look like a 4wd? i am pretty sure just blocks and new u bolts in the rear, but i am lost for the front. i cant find a leveling kit for a 2wd. would i have to get a full lift kit? if so, might as well go 4wd in the first place due to cost. any opinions will be great.
twin i-beam is pretty tricky you cant really level it witouth throwing the camber waaaay off. i think you will need to buy a full suspension lift..just go for a 4x4. you say you dont need it now but ull be glad you have it when u cant move in 2wd. also much easier to re-sell later on.
Originally Posted by freekyFX4
Super Duty trucks don't have twin I-beam suspension...they have a solid front axle.
Sigh, he's talking about a 4x2 suspension not a 4x4
The biggest difference between the front suspension in the 2wd and the 4wd is the coil springs and shocks.
And where did you come to this determination? There is most definetly more of a difference between a 4x4 and 4x2 suspension. The SD line has always used a monobeam axle on the 4x4 models and a TTB suspension on the 4x2 models (except the F450 and F550 which does use a monobeam, but that is not what the OP was buying). The only other truck besides the F450/550 that used a monobeam on a 2wd was the Jeep Cherokee. 2wd trucks typically use a TTB or SLA style suspension, at least for the last 20-25 years anyways.
BTW all the specs on the suspension is readily available on the Ford SD Specs page.
The poster talking about cambur is 100% correct in that you are better going with a lift if you can. The Rangers used a very similar setup from 83-97, as well as the 80-96 F150s. The cambur/caster battle can be a constant battle if you slap something together. A 3" kit should put you about the same level as a stock 4x4 with the plow package. While cheaper to begin with the resale will be lower, so since you want the look of the 4x4 anyways you might be ahead to buy one. It'll pay off when trying to sell or trade.
Wow...learn something new every day. I had no idea that the 2wd and 4wd trucks were so different. Sounds like it would be tough to make a 2wd look like a 4wd then. Good luck!
