oil filter location on 08 6.4 powerstroke
under the hood you will see 2 black caps with a 36mm hex head on them. the one towards the passenger side holds the oil filter and the one towards the drivers side holds a fuel filter. it is a cartridge type filter just like on the 6.0. there is also another fuel filter located on the drivers side frame rail with the same type of cap on it and a lever to drain out water from the seperator.
