04 blew headgaskets
04 blew headgaskets
My bud has an 04 6.0. Has the bully dog chip. Saturday we were racing it a little, well we parked it and it was dripping antifreeze. its was coming out of the cap, so we just figured the cap was faulty. well Sunday he got on it again and its blowing white smoke really really bad, and its missing, running like crap, well at idle, with the coolant cap off, its blowing air bubbles really bad, so i know what that means. He took it to the dealer, took the chip out, left the bully dog sticker on the back window, and told them what happened, well warranty was going to pay until the saw that sticker. now they are denying it, and charging him $3,000. Can they do that?
Well that pretty much says it all right there.
Are you fawking serious? Of course they can do that and most definetly SHOULD void his powertrain warranty. He screwed the pooch when he put a chip on the truck. It states right in the warranty paperwork that you are in breach of contract when you modifiy the vehicle beyond stock. The warranty is most likely voided and the VIN number for the truck has been red flagged in the OASIS system so as soon as any dealer pulls that VIN up they'll tell him to go pound sand. No more 5yr/100k warranty for him.
Your friend didn't know what he was doing (Bully Dog is one of the worst for the 6.0L) and now gets to pay the piper. The chip flash boiled the coolant in the head stretching the studs. Thats not an easy fix, as either the cab has to come off or the engine has to be pulled.
ford obviously knew they had a problem with the head gaskets blowing. im not sure if any of you are aware but after the 04 models, they increased the gaskets from 2mm to 6mm because of the know issue if gaskets being blown. Ford needs to prove that the chip caused the problem, and you can easily argue that Ford was aware of their poor design due to the modification in the gasket thickness. However, once you are red flagged in the system, you are **** out of luck. Make sure when Ford fixes your head gaskets, that they install the new thicker gaskets, as well as stronger bolts that wont stretch under high temperatures. Also look into an extended warranty after Ford solves the problem.
I hate to hear that. The head bolts are the wekest link in the 6.0's and the main reason I didn't buy one. Ford really beefed up the 6.4L engine so that they would not have a repeat of what happened with the 6.0's. I have always heard that if you modify a 6.0L, you should swap out the head bolts with studs.
I havent looked at his truck, but the dealer is putting stronger studs and thicker gaskets, they told him these will work well with his chip... like they really know.
so the dealer is supplying these so called stronger studs?
MAKE SURE you are getting ARP racing studs or something equivalent, at this point with the truck tore apart, don't settle for an inferior stud or especially the stretch to yield replacement bolts or you will be doing this all over again. The newer stock head gaskets should be fine however.
