V10 changes and specs revisited..
What years recieved power upgrades on the V10? I believe 2001 received one over the previous years, did it not?
Then in 2005, the 3valve was introduced, correct?
Other than the obvious, what are the other differences between a 2 and 3 valve V10engine?
I know this is relative, but does the 3valve garner more mpg than the 2valve?
I have a 2001 V10 crewcab Lariat and the power is more than adequate, although at times I had thought it should have performed better than it did.
As many of you may know, i'm in the market for a used 4x4 (mines a 4x2) and i've pretty much decided to stick with the SuperDuty line and the V10 engine so i'm now just trying to get some final questions answered...
Thanks all....
Thanks all....
Histpry of the Triton V10 (ref Wikipedia)
2-valve
1997-present Ford E-Series, 2-valve SOHC, 305 hp and 420 lb·ft ratings for 2001 and later model years
1999-2004 Ford F-Series Super Duty, 2-valve SOHC, 310 hp and 425 lb·ft ratings for 2001 and later model years
2000-2005 Ford Excursion, 2-valve SOHC, 310 hp and 425 lb·ft ratings for 2001 and later model years
3-valve
2005-present Ford F-Series Super Duty, 3-valve SOHC, 362 hp and 457 lb·ft
2-valve
3-valve
